When trying to install new letsencrypt certificates on my raspberry-pi apache 2.4 webserver using sudo certbot --apache I get the following error:
Error while running apache2ctl configtest.
Action 'configtest' failed.
The Apache error log may have more information.
apache2: Syntax error on line x of /etc/apache2/apache2.conf: Syntax error on line x of /etc/apache2/sites-enabled/xxx-le-ssl.conf: Expected </VirtualHost> but saw </VirtualHost></IfModule>
How can this error be fixed?
Thanks to the letsencrypt community I found a simple solution.
The error originates from missing newlines at the end of each enabled (apache) site. So you either add them to each file in sites-enabled or 'sites-available' (both usually located in /etc/apache2/) or you can use Yanson's one liner:
for f in /etc/apache2/sites-available/*; do sed -i '$a\' "$f"; done
