110
Was netstat removed in 16.04? Is there an alternative to netstat available in 16.04? Or how do I install netstat in 16.04?
I am running an ubuntu:16.04 container in docker for Windows, it seems that netstat is no longer available... It is available in an ubuntu:14.04 container.
I have tried installing netstat with apt-get but with no luck...
apt-get update
apt-get install netstat
Reading package lists... Done
Building dependency tree
E: Unable to locate package netstat
It might be that the solution to this is very obvious to most devs, however Linux is very new to me... enjoying it a lot!
As you can see from https://packages.ubuntu.com/xenial/amd64/net-tools/filelist, netstat is provided by the net-tools package. Therefore, you can get netstat by running:
sudo apt update
sudo apt install net-tools
net-tools is probably not installed by default in the Docker image for Ubuntu 16.04 to keep the image size as small as possible.
edwinksl
  • 24,109
41
In my opinion is better to begin adapting yourself to new tools.
ss is auto-defined as "another utility to investigate sockets"
ss -ltu
Will show listening sockets for tcp and udp.
For more information you can use ss --help or man ss. The program ss can be found in the iproute2 package.
JamesThomasMoon
  • 303
  • 14
The version of ubuntu that's provided for use in containers has much less installed in it than a typical desktop installation.
Netstat is still available in Ubuntu 16.04 (via the net-tools package). It's just that that package isn't installed inside docker containers by default.
mc0e
  • 368
