I'm new to LAMP environment and I have some issue with my browser viewing ODBC queries. My php code works in the console under root, but if I run the file using www-data as the user it fails the same way as the browser.
Here's the php code:
<?php
error_reporting(E_ALL);
ini_set('display_errors', '1');
$conn = odbc_connect("NetSuite", "username", "pw");
if (!$conn) {
die(' Could not connect: ' . odbc_error($conn));
$query = odbc_prepare($conn, "SELECT CUSTOMER_SERIAL_NUMBER FROM CUSTOMER_SERIAL_NUMBER");
$success = odbc_execute($query, array('Data'));
if($success)
odbc_result_all($query);
here is the error I'm getting in the browser and the console (when running as www-data user):
PHP Warning: odbc_connect(): SQL error: [unixODBC][Driver Manager]Can't open lib '/opt/netsuite/odbcclient/lib64/ivoa25.so' : file not found, SQL state 01000 in SQLConnect in /var/www/html/GetNSData_1.php on line 5
PHP Warning: odbc_error() expects parameter 1 to be resource, boolean given in /var/www/html/GetNSData_1.php on line 8
my driver folder is set to /opt/netsuite/odbcclient/lib64 here is my permission breakdown:
drwxr-xr-x 3 www-data root 4096 Jul 28 16:17 opt
drwxr-xr-x 3 www-data root 4096 Jul 28 16:17 netsuite
drwxr-xr-x 8 www-data root 4096 Aug 17 17:41 odbcclient
drwxr-xr-x 2 www-data www-data 4096 Aug 16 18:39 lib64
All files in the lib64 are set to
-rwxr-xr-x 1 www-data www-data
The php file is currently set to 777.
I just can't figure out what permission is missing or wrong to get www-data to be able to reach the driver. Any help would be greatly appreciated.
