In a host running Ubuntu 14.04.5 LTS I have an user named ci that can create an start unprivilaged lxc containers also running Ubuntu 14.04.5 LTS. The user has the subid range 200000-231071. The configuration file of such a container is:
# Distribution configuration
lxc.include = /usr/share/lxc/config/ubuntu.common.conf
lxc.include = /usr/share/lxc/config/ubuntu.userns.conf
lxc.arch = x86_64
# Nested
lxc.mount.auto = cgroup
lxc.aa_profile = lxc-container-default-with-nesting
# Container specific configuration
lxc.id_map = u 0 200000 65536
lxc.id_map = u 100000 265536 65536
lxc.id_map = g 0 200000 65536
lxc.id_map = g 100000 265536 65536
lxc.rootfs = /home/ci/.local/share/lxc/ci/rootfs
lxc.utsname = ci
# Network configuration
lxc.network.type = veth
lxc.network.flags = up
lxc.network.link = lxcbr0
lxc.network.hwaddr = 00:16:3e:dd:f1:99
The user can create and start the unprivilaged container without issues:
ci@host:~$ lxc-create -t download -n ci -- -d ubuntu -r trusty -a amd64
ci@host:~$ lxc-start -n ci -d
ci@host:~$ lxc-ls --fancy
NAME STATE IPV4 IPV6 AUTOSTART
ci RUNNING 10.0.3.75, 10.0.4.1 - NO
In the host, cgmanager is running:
root@host ~ # ps ax | grep cgmanager
382 ? Ss 0:01 /sbin/cgmanager --sigstop -m name=systemd
In the unprivilaged container ci, cgproxy is running:
root@ci:~# ps ax | grep cgproxy
288 ? Ss 0:00 /sbin/cgproxy --sigstop
In the unprivilaged container ci, a user named jenkins with subid ranges 100000-65535 can create and start unprivilaged containers inside it, i.e. unprivilaged nested containers, but not without some tricks, which are:
After logging in with ssh as user jenkins in the unprivilaged container ci, the result of
cat /proc/self/cgroupis:jenkins@ci:~$ cat /proc/self/cgroup 12:hugetlb:/user/1012.user/11.session/lxc/ci 11:net_prio:/user/1012.user/11.session/lxc/ci 10:perf_event:/user/1012.user/11.session/lxc/ci 9:net_cls:/user/1012.user/11.session/lxc/ci 8:freezer:/user/1012.user/11.session/lxc/ci 7:devices:/user/1012.user/11.session/lxc/ci 6:memory:/user/1012.user/11.session/lxc/ci 5:blkio:/user/1012.user/11.session/lxc/ci 4:name=systemd:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 3:cpuacct:/user/1012.user/11.session/lxc/ci 2:cpu:/user/1012.user/11.session/lxc/ci 1:cpuset:/user/1012.user/11.session/lxc/ciAt this point, jenkins can create a container, but cannot start it:
jenkins@ci:~$ lxc-create -t download -n test -- -d ubuntu -r trusty -a amd64 jenkins@ci:~$ lxc-start -n test lxc_container: cgmanager.c: lxc_cgmanager_create: 301 call to cgmanager_create_sync failed: invalid request lxc_container: cgmanager.c: lxc_cgmanager_create: 303 Failed to create hugetlb:lxc/test lxc_container: cgmanager.c: cgm_create: 650 Error creating cgroup hugetlb:lxc/test lxc_container: start.c: lxc_spawn: 891 failed creating cgroups lxc_container: start.c: __lxc_start: 1121 failed to spawn 'test' lxc_container: lxc_start.c: main: 341 The container failed to start. lxc_container: lxc_start.c: main: 345 Additional information can be obtained by setting the --logfile and --logpriority options.I issue in the container as root:
restart systemd-logindNow as user jenkins in the container, I log out and log in again with ssh. The cgroup has changed and now I can create and run a container:
jenkins@ci:~$ cat /proc/self/cgroup 12:hugetlb:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 11:net_prio:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 10:perf_event:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 9:net_cls:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 8:freezer:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 7:devices:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 6:memory:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 5:blkio:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 4:name=systemd:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 3:cpuacct:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 2:cpu:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session 1:cpuset:/user/1012.user/11.session/lxc/ci/user/1012.user/11.session/lxc/ci/user/107.user/c1.session jenkins@ci:~$ lxc-create -t download -n test -- -d ubuntu -r trusty -a amd64 jenkins@ci:~$ lxc-start -n test -d jenkins@ci:~$ lxc-ls --fancy NAME STATE IPV4 IPV6 AUTOSTART -------------------------------------------- test RUNNING 10.0.4.64 - NO
First question: why do I need restart systemd-logind and how can I avoid typing it as root before being able to create nested unprivilaged containers?
In the container ci, I have created an init configuration file (an upstart conf file at /etc/init/jenkins.conf) to run the software Jenkins as user jenkins:
description "jenkins"
start on filesystem and static-network-up
stop on runlevel [016]
env USER="jenkins"
env GROUP="jenkins"
env HOME="/var/lib/jenkins"
env JENKINS_LOG="/var/log/jenkins"
env JENKINS_ROOT="/usr/share/jenkins"
env JENKINS_RUN="/var/run/jenkins"
env JENKINS_PIDFILE="jenkins.pid"
pre-start script
test -f $JENKINS_ROOT/jenkins.war || { stop ; exit 0; }
mkdir $JENKINS_RUN > /dev/null 2>&1 || true
chown -R $USER:$GROUP $JENKINS_RUN || true
mkdir $JENKINS_LOG > /dev/null 2>&1 || true
chown -R $USER:$GROUP $JENKINS_LOG || true
end script
script
. /etc/default/jenkins
# export XDG_SESSION_ID="/run/user/`id -u $USER`"
export HOME
export USER
export GROUP
exec daemon --name=jenkins --foreground --inherit --user=$USER:$GROUP --pidfile=$JENKINS_RUN/$JENKINS_PIDFILE --output=$JENKINS_LOG -- $JAVA $JAVA_ARGS -jar $JENKINS_WAR $JENKINS_ARGS
end script
post-start script
while [ ! -f $JENKINS_RUN/$JENKINS_PIDFILE ]; do sleep 1; done
PID=$(cat $JENKINS_RUN/$JENKINS_PIDFILE)
cgm create all $USER
cgm chown all $USER $(id -u $USER) $(id -g $USER)
# this need to be run in the jenkins job script:
# cgm movepid all $USER $$
end script
# vim: ft=upstart
In the script that the process Jenkins issues to start a so called Jenkins' build, if I add the line:
the script can create and start unprivilaged nested containers, being its cgroup:
+ cat /proc/self/cgroup
12:hugetlb:/user/1012.user/11.session/lxc/ci/jenkins
11:net_prio:/user/1012.user/11.session/lxc/ci/jenkins
10:perf_event:/user/1012.user/11.session/lxc/ci/jenkins
9:net_cls:/user/1012.user/11.session/lxc/ci/jenkins
8:freezer:/user/1012.user/11.session/lxc/ci/jenkins
7:devices:/user/1012.user/11.session/lxc/ci/jenkins
6:memory:/user/1012.user/11.session/lxc/ci/jenkins
5:blkio:/user/1012.user/11.session/lxc/ci/jenkins
4:name=systemd:/user/1012.user/11.session/lxc/ci/jenkins
3:cpuacct:/user/1012.user/11.session/lxc/ci/jenkins
2:cpu:/user/1012.user/11.session/lxc/ci/jenkins
1:cpuset:/user/1012.user/11.session/lxc/ci/jenkins
but a user jenkins logged in with ssh cannot stop the container created by the script. The following never finishes:
jenkins@ci:~$ lxc-stop -n test
Second question: how can I achieve that the user jenkins can stop any container created by the user jenkins from an init script like the above?
