11
When I start my PC, the following commands appear in cmd space:
/dev/sda1 contains a file system with errors, check forced.
Inodes that were part of a corrupted orphan linked list found.
/dev/sda1: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
fsck exited with status code 4
The root filesystem on `/dev/sda1` requires a manual `fsck`
BusyBox v1.22.1 (Ubuntu 1:1.22.0-15ubuntu1) built-in shell (ash)
Enter 'help' for a list of built-in-commands.
(initramfs)_
Can anybody help in sorting out the issue? Thanks!
Sherlock
  • 111
  1. At the command-line, enter: "fsck /dev/sda6"
  2. Enter y when prompted to perform fixes.
https://ubuntuforums.org/showthread.php?t=789454
crane
  • 221
To avoid data loss due to disk failure, this command should be given from a live Ubuntu session. Follow these steps:
  • You should burn a live Ubuntu CD.
  • Insert the live CD and try Ubuntu without installing.
  • Open a terminal and type the following command:
    sudo fsck /dev/sda1
  • When prompted, type y to fix the errors.
That should be all. Your system will boot normally once this fix has been applied.
muru
  • 207,228
