Supposedly there is some built in hard drive magic called "Secure Erase" which is wildly faster and more secure than "dd if=/dev/zero..."
I am most excited about the speed increase.
There seems to be a GUI for it as part of Parted Magic: http://www.ocztechnologyforum.com/forum/showthread.php?81321-Secure-Erase-With-bootable-CD-USB-Linux..-Point-and-Click-Method
Is there something like this for Ubuntu? Better yet, is there a way to actually issue this command "manually" like with smartctl or something?
Mikey
  • 185
Secure Erase is part of ATA standard and it is supported by stock-standard hdparm program:
  ATA Security Feature Set
These switches are DANGEROUS to experiment with, and might not work with some kernels. USE AT YOUR OWN RISK.
--security-help Display terse usage info for all of the --security-* options.
--security-freeze Freeze the drive“s security settings. The drive does not accept any security commands until next power-on reset. Use this function in combination with --security-unlock to protect drive from any attempt to set a new password. Can be used standalone, too. No other options are permitted on the command line with this one.
--security-unlock PWD Unlock the drive, using password PWD. Password is given as an ASCII string and is padded with NULs to reach 32 bytes. The applicable drive password is selected with the --user-master switch (default is "user" password). No other options are permitted on the command line with this one.
--security-set-pass PWD Lock the drive, using password PWD (Set Password) (DANGEROUS). Password is given as an ASCII string and is padded with NULs to reach 32 bytes. Use the special password NULL to set an empty password. The applicable drive password is selected with the --user-master switch (default is "user" password) and the applicable security mode with the --security-mode switch. No other options are permitted on the command line with this one.
--security-disable PWD Disable drive locking, using password PWD. Password is given as an ASCII string and is padded with NULs to reach 32 bytes. The applicable drive password is selected with the --user-master switch (default is "user" password). No other options are permitted on the command line with this one.
--security-erase PWD Erase (locked) drive, using password PWD (DANGEROUS). Password is given as an ASCII string and is padded with NULs to reach 32 bytes. Use the special password NULL to represent an empty password. The applicable drive password is selected with the --user-master switch (default is "user" password). No other options are permitted on the command line with this one.
--security-erase-enhanced PWD Enhanced erase (locked) drive, using password PWD (DANGEROUS). Password is given as an ASCII string and is padded with NULs to reach 32 bytes. The applicable drive password is selected with the --user-master switch (default is "user" password). No other options are permitted on the command line with this one.
--user-master USER Specifies which password (user/master) to select. Defaults to user password. Only useful in combination with --security-unlock, --security-set-pass, --security-disable, --security-erase or --security-erase-enhanced. u user password m master password
--security-mode MODE Specifies which security mode (high/maximum) to set. Defaults to high. Only useful in combination with --security- set-pass. h high security m maximum security
      THIS FEATURE IS EXPERIMENTAL AND NOT WELL TESTED. USE AT YOUR OWN RISK.
For obvious reasons, I haven't tested those options, you'll need to see if they work yourself :)
Sergey
  • 44,353
