After performing a clean install of Ubuntu 16.04, my WiFi is trying to connect when disabled. My router WiFi is disabled so my system is hard wired via the ethernet connection. So I don't need the WiFi unless I'm out and about. Both the WiFi and the ethernet operate and connect just fine so there is no problem with the actual connectivity. The hardware works.
However, with the wired ethernet connected, I disable the WiFi via the network indicator in the panel. After the Upgrade, while disabled the WiFi still continues to seek a connection, which because of the router and my location, it can barely detect. So I get constant notifications that I don't have a connection, then I do, then don't, etc.
What could be happening such that with 14.04 the WiFi was disabled when disabled but now with 16.04 disabled is not disabled although it says it's disabled. There's no hardware switch to enable or disable the WiFi and the keyboard function toggle has never worked. It's just permanently "on" and does nothing which is fine with me.
I have an HP ENVY 17 Laptop and the wireless device is an Intel Dual-Band Wireless 3160 (rev 83).
My networking info is are as follows:
lspci
01:00.0 Network controller [0280]: Intel Corporation Wireless 3160 [8086:08b3] (rev 83)
    DeviceName:
    Subsystem: Intel Corporation Dual Band Wireless-AC 3160 [8086:0070]
09:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd.
RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
    DeviceName: Hanksville Gbe Lan Connection
    Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [103c:1965]
lsusb
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 002: ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 004: ID 05c8:036e Cheng Uei Precision Industry Co., Ltd (Foxlink) Webcam
Bus 002 Device 003: ID 8087:07dc Intel Corp.
Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 002 Device 006: ID 138a:0050 Validity Sensors, Inc. Swipe Fingerprint Sensor
Bus 002 Device 005: ID 0eef:a80f D-WAV Scientific Co., Ltd
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
rfkill
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: yes
    Hard blocked: no
ifconfig
eth0      Link encap:Ethernet  HWaddr <MAC 'eth0' [IF1]>
          inet addr:192.168.1.4  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::5461:abea:fced:c913/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:7858 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6426 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:7406246 (7.4 MB)  TX bytes:883972 (883.9 KB)
wlan0     Link encap:Ethernet  HWaddr <MAC 'wlan0' [IF2]>
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:9 errors:0 dropped:0 overruns:0 frame:0
          TX packets:226 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1087 (1.0 KB)  TX bytes:41881 (41.8 KB)
iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
wlan0     IEEE 802.11abgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=off
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
Thanks.
Gryu
  • 8,002
  • 37
  • 53
Exomancer
  • 129
If "fn+f12" isnt working it might be worth asking HP how you can fix that? Might be a simpler process?
Other wise you might need to use a work around, I found the answers and links here to be helpful:
How to switch off wifi on startup or from the console
The only issue here is you'll need to undo it when you want to use the Wifi again... good luck!
