Note: The Workaround section has been kept for historical reasons, however please skip down to the Fix section below.
Workaround:
As stated here:
The good news -- and, yes, there is good news -- is it's easy to fix.
First, Linux itself is being patched to stop the attack vector in its
track. Next, you simply raise the 'challenge ACK limit' to an
extremely large value to make it practically impossible to exploit the
side channel problem that enabled the attack to work.
As this issue affects both the client and server, or in fact any two Linux machines talking over the network, it is important to implement the workaround in both, and the fix as soon as it is released.
In order to implement the workaround do the following:
- Open the config file with:
sudoedit /etc/sysctl.conf
- Insert the line
net.ipv4.tcp_challenge_ack_limit = 999999999 into the file and save it
- Run
sudo sysctl -p to update the configuration
You can also do the operation directly from Terminal:
sudo bash -c 'echo "net.ipv4.tcp_challenge_ack_limit = 999999999" >>/etc/sysctl.conf'
Or:
echo 'net.ipv4.tcp_challenge_ack_limit = 999999999' | sudo tee -a /etc/sysctl.conf
Then run:
sudo sysctl -p
Fix:
As stated here:
net/ipv4/tcp_input.c in the Linux kernel before 4.7 does not properly
determine the rate of challenge ACK segments, which makes it easier for
man-in-the-middle attackers to hijack TCP sessions via a blind in-window
attack.
sbeattie> fix is going to land in Ubuntu kernels in this SRU cycle,
with a likely release date of Aug 27. Earlier access to the kernels
with the fix will be available from the -proposed pocket, though they
come with the risk of being less tested.
And a fix has now been released:
linux (4.4.0-36.55) xenial; urgency=low
[ Stefan Bader ]
* Release Tracking Bug
- LP: #1612305
* I2C touchpad does not work on AMD platform (LP: #1612006)
- SAUCE: pinctrl/amd: Remove the default de-bounce time
* CVE-2016-5696
- tcp: make challenge acks less predictable
-- Stefan Bader <stefan.bader@canonical.com> Thu, 11 Aug 2016 17:34:14 +0200
Run:
sudo apt-get update
sudo apt-get dist-upgrade
To make sure you have the latest version. Or use the Software Updater if you would prefer to update through the GUI.
You can check which version you are running and which is available with:
apt-cache policy linux-image-generic
