Intel NUC6i7KYK with Iris Pro 580 on Ubuntu 16.04.1 .
Mini-DP from NUC to DP 1.2 on monitor works great (4K @ 60Hz).
HDMI from NUC to HDMI 2.0 on monitor shows the POST at boot (booting from installation on USB as well as SSD), shows grub, then shows the Ubuntu logo with the little progress dots beneath it, then shows the purple screen, then ... monitor shows no signal.
When hooking up to my TV, which does not have HDMI 2.0, it works fine.
When using a mini DP from the NUC adapted to HDMI on the monitor, it works fine (though only 30Hz as expected).
When running a windows installation, it works fine.
The driver shows that it is recognizing it is Iris Pro 580 (from the system info screen in ubuntu).
So the problem config is: HDMI 2.0 source (NUC), HDMI 2.0 monitor (LG 27UD68), Ubuntu.
Any ideas? I've been through quite a few iterations to narrow it down this far, but the driver seems right.
