14
Similar to This question, but different result set, can anyone help me with the output of getent group?
It's something like this:
groupname:x:0:
just not sure what the x:0: signifies?
twitchd8
  • 147
getent group <group_name>
queries the /etc/group file and gets the entry for the mentioned group from the file.
The output format is:
group:password:GID:user(s)
  • group is the group's name
  • password is the encrypted group password, empty field signifies no password, x bit signifies the password is in the file /etc/gshadow
  • GID is the Group ID
  • user(s) is the list of users member of this group, empty means this group has no member.
Now, if you check the /etc/gshadow file you will see that the group password is locked (! or *) in the password field, thats because the group password is not used. It's considered a security risk to have all members of the group share the same password. (At least i have never come across any implementation of gshadow).
heemayl
  • 93,925
The accepted answer is not complete. getent also reads SSSD info to get LDAP group which is not listed in /etc/group. cat /etc/nsswitch.conf and check the group line to see what group info source you have.
# /etc/nsswitch.conf
# Example configuration of GNU Name Service Switch functionality.
# If you have the `glibc-doc-reference' and `info' packages installed, try:
# `info libc "Name Service Switch"' for information about this file.
passwd: compat systemd sss group: compat systemd sss shadow: compat sss gshadow: files
hosts: files mdns4_minimal [NOTFOUND=return] dns myhostname networks: files
protocols: db files services: db files sss ethers: db files rpc: db files
netgroup: nis sss sudoers: files sss
