I use keepass to store some password. The folder containing the file foo.kdbx is shared via owncloud.
I see that a file called foo_conflict-20160810-075402.kdbx was created.
I exported the foo.kdbx and foo_conflict-20160810-075402.kdbx to the xml format and compared both using the tool meld.
I see a lot of changes on fields with these names:
  • LastAccessTime
  • UsageCount
  • LastTopVisibleEntry
Is there a way to tell keepass (I use the desktop and the android version) to not save these unimportant meta data changes?
I want reading a value from keepass to be read-only. Otherwise I need to resolve the conflict which costs too much time.
guettli
  • 1,765
I'm not very familiar with owncloud or how it handles file conflicts, but there are a few Keepass options you can change to try to get the functionality you want.
If you want Keepass read-only and always have it open on the source machine, you can try using Keepass's native lock files option under Tools → Options → Advanced → File Input/Output Connections → Use database lock files. I would assume that would provide a similar function, though it probably isn't the most secure way to do things.
You can also try the Do not ask whether to synchronize or overwrite; force synchronization option (in the same section) to ensure your database updates are always synced, which (I believe) should prevent most if not all conflicts.
For the actual data storage, while you can hide or show details like "Last Modification Time", I'm pretty sure you can't actually remove the variable or tell Keepass not to track that information.
Boxbot
  • 114
