I am seeing strange issue with 73-usb-net-by-mac.rules file.
This udev rule file has the check if the net.ifnames is defined in kernel command line then it will go to the end and skip the rules in between as below:
IMPORT{cmdline}="net.ifnames", ENV{net.ifnames}=="0", GOTO="usb_net_by_mac_end"
Somehow this is not working at my end. I mean I have net.ifnames=0 in my kernel command line and still the usb net naming rule is executed.
If I split the above rule line like below then it works fine as it supposed to work:
Is it like the udev doesn't parse the keys after IMPORT key on the same line?
Could you please let me know if am doing something wrong or the rule needs to be changed?
