I wrote a python script to autogenerate a background pattern for my computer. I want to use cron to run it every 15 minutes or so. Here's the code:
#!/usr/bin/python
import os
import numpy as np
import svgwrite as svg
WIDTH = 1600
HEIGHT = 900
def circle_layer(dwg, size_range, blur, number):
    blur_filter = dwg.defs.add(dwg.filter())
    blur_filter.feGaussianBlur(in_='SourceGraphic', stdDeviation=blur)
    g_f = dwg.add(dwg.g(filter=blur_filter.get_funciri()))
    for c in xrange(0, number):
        (x, y) = (np.random.random_integers(0,WIDTH),    np.random.random_integers(0,HEIGHT))
        rad = np.random.random_integers(size_range[0], size_range[1])
        g_f.add(dwg.circle(center=(str(x),str(y)), r=str(rad),stroke="rgb(100,100,100)", fill="rgb(100,0,0)"))
    return dwg
if __name__ == "__main__":
    svg_doc = svg.Drawing(filename = "current_wallpaper.svg", size = (str(WIDTH), str(HEIGHT)))
    svg_doc.add(svg_doc.rect(insert=(0,0), size=(str(WIDTH), str(HEIGHT)), fill="rgb(0,0,0)"))
    svg_doc = circle_layer(svg_doc, (10,50),  20, 100)
    svg_doc = circle_layer(svg_doc, (10, 20), 4, 100)
    svg_doc.save()
    import subprocess
    proc = subprocess.Popen(["pgrep gnome-session"], stdout=subprocess.PIPE, shell=True)
    (pid, err) = proc.communicate()
    pid = pid.rstrip('\t\r\n\0')
    print repr(pid)
    cmd = "grep -z DBUS_SESSION_BUS_ADDRESS /proc/"+pid+"/environ|cut -d= -f2-"
    proc = subprocess.Popen([cmd], stdout=subprocess.PIPE, shell=True)
    (out, err) = proc.communicate()
    out = out.rstrip('\t\r\n\0')
    print repr(out)
    cmd = "export DBUS_SESSION_BUS_ADDRESS=$"+out
    print repr(cmd)
    os.system(cmd)
    os.system("/usr/bin/gsettings set org.gnome.desktop.background picture-uri file:///home/jofo/Pictures/Wallpapers/current_wallpaper.svg")
    print "I ran!"
Basically, it uses svgwrite to draw some circles and add a gaussian blur. Then, I make a system call to gsettings to update the ubuntu wallpaper.
This works fine when I run it as ./wallpaper.py, but when I schedule it in crontab, the script runs, and the background pattern doesn't change.
Here's what I have in my crontab file doohickey:
MAILTO=""
*/1 * * * * /home/jofo/Pictures/Wallpapers/./wallpaper.py >> /home/jofo/Pictures/Wallpapers/cron.log
I know the script is running once a minute because it appends "I ran!" to the cron.log file once per minute. Unfortunately, the wallpaper never changes. If anyone knows why this might be, that would be great!
J. Ford
  • 55
