I installed a fresh new version of ubuntu 16.04 on my system, parallel to windows, and have some trouble understanding why my grub is so slow:
Basically, grub seems to run normally until I select an entry in the menu. Then, the menu disappears, but grub's background (ubuntu's default purple color) hangs there for around 20 seconds, before handing control to the operating system. I removed quiet & splash to distinguish better.
Here's my config file:
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=false
GRUB_TIMEOUT=1
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="i915.preliminary_hw_support=1 acpi_backlight=vendor"
GRUB_CMDLINE_LINUX=""
GRUB_GFXMODE=640x480
I tried different things:
  • uncommenting the GRUB_GFXMODE=640x480, faster in the menu, but not helping for the hanging after the system is chosen.
  • I tried the hidden timeout thing, thinking that was the reason, but it isn't the case.
  • The linux flags I added (acpi + intel's hardware support) are not the cause of the slowdown, since I had the same problem before adding them.
I have not much experience with grub, I used syslinux on arch linux before, (which was faster than light =) but had to quit arch because I needed a more stable system. Still I don't think this is grub's standard behavior =D.
For the record, I have a gigabyte laptop with a skylake i7 HQ processor and a ssd for storage.
Anyone knows where this issue comes from? Thanks in advance!
Up?
I know this isn't a critical issue, but 20sec to load the initial ramdisk is a quite annoying lag.. :/
I unsuccessfully tried a boot-repair, which reinstalled grub with the same issue in the end.
Mitch
  • 109,787
lagarkane
  • 151
Bring your system up to date so that you get the current kernel with
sudo apt update sudo apt upgrade
After completion and reboot if necessary the output of uname -a should be 4.4.0-36 generic or newer.
Remove i915.preliminary_hw_support=1 from your config and update grub as usual. This will likely alleviate the confusion that I believe is the source of your delay at kernel launch
Source: http://www.phoronix.com/scan.php?page=news_item&px=intel-slk-linux-4.3-no-prelim
Elder Geek
  • 36,752
