I am running a fresh install of Ubuntu 14.04. I just downloaded the latest version of steam install files.
When running install a terminal is opened and the following text is output to the terminal:
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
 libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.6)
 unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
                        Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Press return to continue:
then I get and error that says
You are missing the following 32-bit libraries, and Steam may not run:
libGL.so.1
I have tried all sorts of googled solutions like getting packages and updating my steam.conf file.
EDIT: I should mention that I have not installed nvidia drivers for my gt 710. I just used the existing ones that are auto installed by Ubuntu. Could these be insufficient?
Scorb
  • 1,330
Try to install the library before:
sudo apt-get install --reinstall libgl1-mesa-dri:i386
Than install Steam:
sudo apt-get install -y steam
Source: https://ubuntuforums.org/showthread.php?t=2233005
Benny
  • 5,100
