Ubuntu 16.04. After upgrade I restarted and my locked to launcher icons disapperead. Now every time I restart I have a clean launcher with standard icons. If I try to open applications and lock to launcher them, after restart they will disappear. Any help?
Asked
Active
Viewed 211 times
Problem solved! The issue origin was because some days ago I installed gnome glib-2.0 for c development purpose. I don't know why only after the update the problem arose. To discover the problem: from command line after doing:
$ unity-control-center
I can see the error:
GLib-Gio-Message: Using the 'memory' GSettings backend. Your settings will not be saved or shared with other applications.
The problem is that in the search path the installed glib (under usr/local) is searched before the library referenced by unity.
To solve the problem I ran sudo make uninstall from the directory where I downloaded gnome glib. After reboot every icon and setting was restored automatically.
Eventually it would be possible to change the search path of dynamic libraries defined in /etc/ld.so.conf.d/.
See also My dconf/gsettings installation is broken. How can I fix it without Ubuntu reinstall?
