I had windows and Linux dual boot on my computer. I now want to get rid of windows and do a clean install of Ubuntu, with a separate home partition. After setting my root, swap and home partitions as desired I get the following warning.
"The partition table format in use on your disks normally requires you to create a separate partition for boot loader code. This partition should be marked for use as a "Reserved BIOS boot area" and should be at least 1MB in size. Note that this is not the same as a partition mounted on /boot.
If you do not go back to the partitioning menu and correct this error, boot loader installation may fail later, although it may still be possible to install the boot loader to a partition."
Here are my new partitions settings:
  • free space 1 MB
  • sda1 Ext4 ./ 30720 MB
  • sda2 swap 4096 MB
  • sda3 Ext4 /home 465290 MB
  • free space 1 MB
I would guess this warning is relevant if was to reinstall on a dual boot but can be discarded in my case.
Is this right?
gilles
