I'm running a compilation process that can take up to several days to complete on Ubuntu Server 16.04 .
I generally remote into this server using putty SSH, however I've run into a problem. Once I exit my putty session, the compilation terminates.
How can I make my process keep running after I exit Putty?
Edon
  • 211
  1. Background the process and use nohup to ignore SIGHUP:
    nohup make-foo arguments &
  2. Run the compilation command in a terminal multiplexer, such as tmux or GNU screen. This allows both for the compilation to continue after you detach, and to be able to reattach to the same terminal at a later time to review output.
user4556274
  • 5,097
