After upgrading my Ubuntu, I get this message:
/dev/sda2: clean, 908443/38690816 Files, 44176803/154733312 Blocks
and nothing happens.
Any suggestions to solve it?
I found this post related to my question, however, there is 30 sec problem there not lasting forever! My Ubuntu is running fsck on every bootup
So, my question is not about the content of this message since it's a normal fsck output. But the question is about why the system does not boot afterwards.
6 Answers6
Guys it is a graphics driver problem. I solved it by uninstalling all the proprietary drivers and switching to open source drivers.
Press ctrl+alt+F2 and enter your username and password to get bash
Once in bash
https://linuxconfig.org/how-to-uninstall-the-nvidia-drivers-on-ubuntu-20-04-focal-fossa-linux
Follow the steps in the above link and uninstall all proprietary drivers and reboot with the reboot command. That's all it took to fix my issue.
I faced the same issue on my Ubuntu 20.04 LTS. In my case the problem was that I downloaded some large files and, without noticing, I completely filled my HDD.
I was able to solve the boot problem by:
  1. Creating a bootable USB disk (tutorial here).
  2. I attached this USB stick and boot into the Ubuntu with the Try Ubuntu option.
  3. I checked the HDD capacity. The sda2 storage was 256 GB and it displayed 0/256 GB available.
  4. I tried to delete files using GUI, which did not work.
  5. I opened a terminal and used sudo to delete some unnecessary files:
    sudo rm -r <folder name here>
  6. I freed up around 150+ MB and then removed the bootable stick and rebooted my system
Voila, it worked!!
I think you have no problem. It's just a normal procedure in ubuntu versions 15 and newer. I offer a link to the explanation given by its author https://answers.launchpad.net/ubuntu/+question/293967
Ubuntu versions 15.04 and newer perform a quick file system check on the root disk and report the result on the screen.
The message /dev/sda2: clean, 286631/6111232 files, 2586472/24413952 blocks has the following meaning:
The partition that was checked is "/dev/sda" The file system is "clean", i.e. there are no inconsistencies "286631/6111232 files": The file system has been created to allow a maximum of 6,111,232 files, and currently there are 286,631 files, "2586472/24413952 blocks": The storage capacity of the file system is 24,413,952 blocks (probably 4096 bytes each), and 2,586,472 blocks currently are in use.
This is an informational message confirming that the file system is ok. There is nothing that needs to be resolved or repaired.
Anwar
  • 77,855
I solved same problem by using the following steps,
Ctrl + Alt + F2 OR F3
  • login with your account
  • type sudo apt-get update Enter password when prompted
  • type sudo apt-get install
  • reboot
Jeff
  • 1,724
If you are using ubuntu 20+. Click ctrl+alt+f2 . A Login terminal will appear, go ahead and use your username and password.
Once in you try to list your home directory, if this works out this implies that your gdm3 is the problem. To solve this use this command....and Tada! You got it
sudo apt install gdm3
Please try sudo systemctl start lightdm.service This works for Ubuntu 16.04. Hope it helps.
Reference: Ubuntu 16.04 Switch from Console to GUI
Bruce Yo
  • 160
