88
I just can't figure a way to change my Bluetooth device name.
Is there any command?
Daniel
  • 1,288
Newbi
  • 2,219
12 Answers12
89
It seems the option was removed from the Bluetooth control panel, but you should still be able to change the name via the command line:
sudo hciconfig hci0 name 'Device Name'
Once you run the command, you should be able to verify the change by bringing up the Bluetooth control panel again and checking the device name.
74
You can't change bluetooth device name from control panel in ubuntu yet. Here is the bug report, which provides this workaround:
If you want to change the bluetooth device name permanently, you have to create a file called /etc/machine-info which should have the following content:
PRETTY_HOSTNAME=device-name
After this, restart the Bluetooth service:
sudo service bluetooth restart
Or reboot.
Daniel
  • 1,288
subhajit
  • 1,006
What I did (on 12.04):
  1. device name is stored in /var/lib/bluetooth/XX:XX:XX:XX:XX:XX/config
  2. delete it
  3. restart (~# service bluetooth restart)
  4. device name is rewritten in config (according to /etc/bluetooth/main.conf ?)
Marx
  • 231
I am using Blueman Bluetooth Manager. There is an option to change a computer's BT name in:
Adapter → Parameters
user.dz
  • 49,176
To change the bluetooth host name permanently, on Ubuntu 14.04 or later:
Open a terminal with CTRL-ALT-T
  1. Edit /etc/bluetooth/main.conf replacing "%h" with the computer name you want. "%h" always seems to represent "ubuntu" on my systems for some reason.
    gksudo gedit /etc/bluetooth/main.conf
    For example change Name = %h-%d to Name = gruber-%d `
  2. Remove /var/lib/bluetooth/xx:xx:xx:xx:xx:xx/config to make your system forget the old name. The xx:xx:xx:xx:xx:xx has a hexadecimal value unique to your bluetooth hardware.
    sudo rm /var/lib/bluetooth/xx:xx:xx:xx:xx:xx/config
  3. Restart the bluetooth service
    (Under 15.04 or later:)
    sudo systemctl restart bluetooth.service
You can check the new name by opening the Bluetooth settings. The last two steps are from Marx's answer.
John S Gruber
  • 13,436
The default Bluetooth package (bluez) comes with a command-line utility bluetoothctl that can set/reset the broadcast name (the "controller alias").
To change the broadcast name to new-name:
bluetoothctl system-alias new-name
To remove the alias, setting the broadcast name back to your computer's name:
bluetoothctl reset-alias
This will modify the appropriate settings in /var/lib/bluetooth automatically. MakeUseOf has a nice introduction on what you can do with bluetoothctl.
You can change the name of a bluetooth remote device on your PC :
  1. check the MAC adress of the device in the bluetooth settings. It looks:
    XX:XX:XX:XX:XX:XX
  2. open the Terminal and type:
    sudo gedit /var/lib/bluetooth/XX:XX:XX:XX:XX:XX/config/info
  3. if it asks for the password, type it (you won't see it)
  4. the gedit will open up with that file.
  5. modify (only) the value corresponding to 'Name'
    Name=modified_name_as_you_like_it
The change will not be instantaneous !
  1. Restart the service (or the PC), using the command:
On Ubuntu 20.04 you can do this from the settings.
Settings > About > Device Name
Reboot your computer for the changes to take effect.
On Ubuntu 24.04. See this answer: Changing bluetooth device name
In summary:
bluetoothctl has a prompt that is accessed simply by running the command.
Its commands can also be used without accessing the prompt, but that way there is no autocompletion.
There is a distinction between external devices (mouse, keyboard, gamepad, etc.), and the host controllers (built-in BT card, external USB BT adapter, etc.).
With bluetoothctl is possible to change both device and controller alias, the process can be summed up in 3 steps:
  • list the available controller/devices
  • select the controller/device to modify
  • modify the controller/device
The commands are:
Controller
  • run bluetoothctl to access its prompt
  • run list to list the available controllers
    • in my case I only have 1 controller, my laptop's BT card
  • run select 00:11:22:33:44:55 to select the controller to modify
    • the address can be autocompleted with TAB, in my case is the only 1 address available
  • run system-alias "new alias for my BT controller" to modify the controller alias
Device
  • run devices to list the available devices
    • the output can be filtered by using optional properties, for example devices Connected
  • run connect AA:BB:CC:DD:EE:FF to select the devices to modify
  • run set-alias "new alias for my BT device" to modify the device alias
stenix
  • 371
In Ubuntu 20.10 look at
sudo grep Alias /var/lib/bluetooth/*/settings
edit the value Alias with
sudo gedit /var/lib/bluetooth/*/settings
For example call it NewDeviceName@yourdomain.net
Then call
sudo hciconfig hci0 name 'NewDeviceName@yourdomain.net'`
No need for reboot or bluetooth restart.
Alternatively you can do this from the settings:
Settings -> Info -> Gerätename
I guess in english it is:
Settings -> About -> Device Name
rubo77
  • 34,024
  • 52
  • 172
  • 299
In Ubuntu 22.04, the following GUI option allows renaming in the Bluetooth Manager:
  1. Bluetooth Manager
  2. Right click on BT device
  3. Rename device
  4. Enter new name
moo
  • 966
dbt
sudo apt-get update; sudo apt-get install -y nano
sudo nano /var/lib/bluetooth/*/config
Update the value for “name”. In my case, it was: Ubuntu-0
