I recently tried to upgrade Ubuntu 14.04 LTS to 16.04 LTS i.e "do-release-upgrade", I am not sure what went wrong but whenever I try to install or update a package I get the below error,
~/COREBOOT/coreboot.org_3rdAug$ sudo apt-get install libftdi1
Reading package lists... Done
Building dependency tree
libftdi1 is already the newest version (0.20-4build1).
libftdi1 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
8 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up bluez (5.37-0ubuntu5) ...
insserv: Service dbus has to be enabled to start service bluetooth
insserv: exiting now!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package bluez (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of gnome-bluetooth:
gnome-bluetooth depends on bluez (>= 5.5); however:
Package bluez is not configured yet.
dpkg: error processing package gnome-bluetooth (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of indicator-bluetooth:
indicator-bluetooth depends on bluez (>= 5); however:
indicator-bluetooth depends on gnome-bluetooth | ubuntu-system-settings; however:
Package gnome-bluetooth is not configured yet.
Package ubuntu-system-settings is not installed.
dpkg: error processing package indicator-bluetooth (--configure):
dpkg: dependency problems prevent configuration of unity-control-center:
unity-control-center depends on indicator-bluetooth; however:
Package indicator-bluetooth is not configured yet.
dpkg: error processing package unity-control-center (--configure):
dependency problemsNo apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of gnome-user-share:
gnome-user-share depends on gnome-bluetooth (>= 3.9.3); however:
dpkg: error processing package gnome-user-share (--configure):
dpkg: dependency problems prevent configuration of gnome-core:
gnome-core depends on gnome-bluetooth (>= 3.14); however:
gnome-core depends on gnome-user-share (>= 3.14); however:
Package gnome-user-share is not configured yet.
dpkg: error processing package gnome-core (--configure):
dpkg: dependency problems prevent configuration of ubuntu-desktop:
ubuntu-desktop depends on unity-control-center; however:
Package unity-control-center is not configured yet.
dpkg: error processing package ubuntu-desktop (--configure):
dpkg: dependency problems prevent configuration of pulseaudio-module-bluetooth:
pulseaudio-module-bluetooth depends on bluez (>= 5.23); however:
dpkg: error processing package pulseaudio-module-bluetooth (--configure):
bluez
gnome-bluetooth
indicator-bluetooth
gnome-user-share
gnome-core
ubuntu-desktop
I figure that this could be be because of
and I tried restarting the dbus service
However I end up with the below error
$ sudo service dbus restart
Failed to restart dbus.service: Operation refused, unit dbus.service may be requested by dependency only.
See system logs and 'systemctl status dbus.service' for details.
Output of systemctl status dbus.service
dbus.service - D-Bus System Message Bus
Loaded: loaded (/lib/systemd/system/dbus.service; static; vendor preset: enabled)
Active: active (running) since Thu 2016-08-04 18:54:45 IST; 4 days ago
Docs: man:dbus-daemon(1)
Process: 2774 ExecReload=/usr/bin/dbus-send --print-reply --system --type=method_call --dest=org.freedesktop.DBus / org.freedesktop.DBus.ReloadConfig (code=exited, status=0/SUCCESS)
Main PID: 3054 (dbus-daemon)
CGroup: /system.slice/dbus.service
└─3054 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
but:
$ sudo dpkg --configure bluez Setting up bluez (5.37-0ubuntu5) ...
bluetooth insserv: exiting now! update-rc.d: error: insserv rejected the script header
dpkg: error processing package bluez (--configure): subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing: bluez
How do I fix this?
