I created a simple desktop file to check the connectivity of remote location in which Exec=ping 192.168.0.9. But one file created with #!/usr/bin/env xdg-open before Desktop Entry and another without #!/usr/bin/env xdg-open and both worked the same. Then What is the use of it in desktop file? What does it mean?
Asked
Active
Viewed 7,443 times
d a i s y
- 5,551
As per this answer , the use of #!/usr/bin/env xdg-open was meant to serve as a way to launch applications that referenced in .desktop file via command line. But as of now, it doesn't work and only opens .desktop file as text file in gedit. Nowadays , if you want to launch a .desktop app via command line, you must do some pre-processing of the file itself.
As for use of #! it basically tells your computer which interpreter to use with this file. In this case, /usr/bin/env which will return path to xdg-open command (i.e, this calls xdg-open to read and execute your file ) .
Sergiy Kolodyazhnyy
- 107,582
