I want to install php7 after upgrading to 16.04 from 14.04. Here is what I get:
Setting up php7.0-fpm (7.0.8-0ubuntu0.16.04.2) ...
Job for php7.0-fpm.service failed because the control process exited with error code. See "systemctl status php7.0-fpm.service" and "journalctl -xe" for details.
    invoke-rc.d: initscript php7.0-fpm, action "start" failed.
    dpkg: error processing package php7.0-fpm (--configure):
     subprocess installed post-installation script returned error exit status 1
     php7.0-fpm
The output of sudo php-fpm7.0 -t is:
[07-Aug-2016 10:32:35] ERROR: failed to open configuration file '/etc/php/7.0/fpm/php-fpm.conf': No such file or directory (2)
[07-Aug-2016 10:32:35] ERROR: failed to load configuration file '/etc/php/7.0/fpm/php-fpm.conf'
[07-Aug-2016 10:32:35] ERROR: FPM initialization failed
edwinksl
  • 24,109
Manee Osman
  • 187
Sorry for inconvenience,
NOTE: i used php7 in 14.04 and removed it and install php5 again. and now i want t install php7 again.
To solve this:
  1. Remove php7.0-fpm: sudo apt-get remove php7.0-fpm
  2. Purge it: sudo apt-get purge php7.0-fpm
  3. Manually remove /etc/php/7.0/fpm directory: sudo rm -rf /etc/php/7.0/fpm/
  4. Install php7.0-fpm again: sudo apt-get install php7.0-fpm
pixeline
  • 143
Manee Osman
  • 187
