Currently running a desktop w/ Ubuntu 16. I have noticed that my internet speed is slower while on Ubuntu than it is booting up in Windows on the same desktop, or using my Macbook. My desktop connects to the router with an ethernet cable, while the Macbook is connected through wi-fi.
What are some possibilities that I could look into this issue?
EDIT: UPDATE! Looking into my Ethernet Im noticing that its a Realtek with the kernel driver r8169 in use. Reading up elsewhere I've seen these drivers be the issue. Im seeing that drivers are available form realtek but those are linux Kernel 3.X and 2.X, while Ubuntu 16 is on the Linux 4 Kernel.
EDIT2: Having run a diagnostics script here is my output
########## wireless info START ##########
Report from: 07 Aug 2016 11:20 PDT -0700
Booted last: 07 Aug 2016 00:00 PDT -0700
Script from: 08 Jul 2016 02:16 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.1 LTS
Release:    16.04
Codename:   xenial
##### kernel ############################
Linux 4.4.0-31-generic #50-Ubuntu SMP Wed Jul 13 00:07:12 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 09)
    Subsystem: ASUSTeK Computer Inc. P8 series motherboard [1043:8505]
    Kernel driver in use: r8168
##### lsusb #############################
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 003: ID 045e:00db Microsoft Corp. Natural Ergonomic Keyboard 4000 V1.0
Bus 005 Device 002: ID 1038:1710 SteelSeries ApS
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 011 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 010 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
##### rfkill ############################
##### lsmod #############################
eeepc_wmi              16384  0
asus_wmi               28672  1 eeepc_wmi
mxm_wmi                16384  0
sparse_keymap          16384  1 asus_wmi
video                  40960  1 asus_wmi
wmi                    20480  2 mxm_wmi,asus_wmi
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
enp2s0    Link encap:Ethernet  HWaddr <MAC 'enp2s0' [IF1]>
          inet addr:192.168.1.5  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::9196:f58b:5175:e8dd/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:26704 errors:0 dropped:0 overruns:0 frame:0
          TX packets:26853 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:24784362 (24.7 MB)  TX bytes:2829572 (2.8 MB)
          Interrupt:43 Base address:0x8000
##### iwconfig ##########################
enp2s0    no wireless extensions.
lo        no wireless extensions.
##### route #############################
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.1     0.0.0.0         UG    100    0        0 enp2s0
169.254.0.0     0.0.0.0         255.255.0.0     U     1000   0        0 enp2s0
192.168.1.0     0.0.0.0         255.255.255.0   U     100    0        0 enp2s0
##### resolv.conf #######################
nameserver 127.0.1.1
##### network managers ##################
Installed:
    NetworkManager
Running:
root      1955     1  0 10:57 ?        00:00:00 /usr/sbin/NetworkManager --no-daemon
##### NetworkManager info ###############
GENERAL.DEVICE:                         enp2s0
GENERAL.TYPE:                           ethernet
GENERAL.NM-TYPE:                        NMDeviceEthernet
GENERAL.VENDOR:                         Realtek Semiconductor Co., Ltd.
GENERAL.PRODUCT:                        RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (P8 series motherboard)
GENERAL.DRIVER:                         r8168
GENERAL.DRIVER-VERSION:                 8.041.00-NAPI
GENERAL.FIRMWARE-VERSION:
GENERAL.HWADDR:                         <MAC 'enp2s0' [IF1]>
GENERAL.MTU:                            1500
GENERAL.STATE:                          100 (connected)
GENERAL.REASON:                         0 (No reason given)
GENERAL.UDI:                            /sys/devices/pci0000:00/0000:00:04.0/0000:02:00.0/net/enp2s0
GENERAL.IP-IFACE:                       enp2s0
GENERAL.IS-SOFTWARE:                    no
GENERAL.NM-MANAGED:                     yes
GENERAL.AUTOCONNECT:                    yes
GENERAL.FIRMWARE-MISSING:               no
GENERAL.NM-PLUGIN-MISSING:              no
GENERAL.PHYS-PORT-ID:                   --
GENERAL.CONNECTION:                     Wired connection 1
GENERAL.CON-UUID:                       17d1f373-9fb8-44e1-ba4f-803dc84587e4
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/0
GENERAL.METERED:                        no (guessed)
CAPABILITIES.CARRIER-DETECT:            yes
CAPABILITIES.SPEED:                     10 Mb/s
CAPABILITIES.IS-SOFTWARE:               no
WIRED-PROPERTIES.CARRIER:               on
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/{0}
CONNECTIONS.AVAILABLE-CONNECTIONS[1]:   17d1f373-9fb8-44e1-ba4f-803dc84587e4 | Wired connection 1
IP4.ADDRESS[1]:                         192.168.1.5/24
IP4.GATEWAY:                            192.168.1.1
IP4.ROUTE[1]:                           dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP4.DNS[1]:                             192.168.1.1
IP4.DNS[2]:                             75.75.76.76
DHCP4.OPTION[1]:                        requested_routers = 1
DHCP4.OPTION[2]:                        requested_domain_search = 1
DHCP4.OPTION[3]:                        requested_time_offset = 1
DHCP4.OPTION[4]:                        requested_domain_name = 1
DHCP4.OPTION[5]:                        requested_rfc3442_classless_static_routes = 1
DHCP4.OPTION[6]:                        requested_broadcast_address = 1
DHCP4.OPTION[7]:                        requested_netbios_scope = 1
DHCP4.OPTION[8]:                        requested_wpad = 1
DHCP4.OPTION[9]:                        next_server = 0.0.0.0
DHCP4.OPTION[10]:                       expiry = 1470679063
DHCP4.OPTION[11]:                       requested_interface_mtu = 1
DHCP4.OPTION[12]:                       requested_subnet_mask = 1
DHCP4.OPTION[13]:                       dhcp_lease_time = 86400
DHCP4.OPTION[14]:                       dhcp_message_type = 5
DHCP4.OPTION[15]:                       ip_address = 192.168.1.5
DHCP4.OPTION[16]:                       requested_static_routes = 1
DHCP4.OPTION[17]:                       requested_domain_name_servers = 1
DHCP4.OPTION[18]:                       routers = 192.168.1.1
DHCP4.OPTION[19]:                       broadcast_address = 192.168.1.255
DHCP4.OPTION[20]:                       requested_ntp_servers = 1
DHCP4.OPTION[21]:                       requested_netbios_name_servers = 1
DHCP4.OPTION[22]:                       domain_name_servers = 192.168.1.1 75.75.76.76
DHCP4.OPTION[23]:                       requested_ms_classless_static_routes = 1
DHCP4.OPTION[24]:                       subnet_mask = 255.255.255.0
DHCP4.OPTION[25]:                       network_number = 192.168.1.0
DHCP4.OPTION[26]:                       requested_host_name = 1
DHCP4.OPTION[27]:                       dhcp_server_identifier = 192.168.1.1
IP6.ADDRESS[1]:                         fe80::9196:f58b:5175:e8dd/64
IP6.GATEWAY:
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
##### iw reg get ########################
Region: America/Los_Angeles (based on set time zone)
country 00: DFS-UNSET
    (2402 - 2472 @ 40), (6, 20), (N/A)
    (2457 - 2482 @ 40), (6, 20), (N/A), PASSIVE-SCAN
    (2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
    (5170 - 5250 @ 160), (6, 20), (N/A), PASSIVE-SCAN
    (5250 - 5330 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
    (5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
    (5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN
    (57240 - 63720 @ 2160), (N/A, 0), (N/A)
##### iwlist channels ###################
enp2s0    no frequency information.
lo        no frequency information.
##### iwlist scan #######################
enp2s0    Interface doesn't support scanning.
lo        Interface doesn't support scanning.
##### module infos ######################
##### module parameters #################
##### /etc/modules ######################
##### modprobe options ##################
[/etc/modprobe.d/amd64-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
[/etc/modprobe.d/r8168-dkms.conf]
alias   pci:v00001186d00004300sv00001186sd00004B10bc*sc*i*  r8168
alias   pci:v000010ECd00008168sv*sd*bc*sc*i*            r8168
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
##### dmesg #############################
[    3.928341] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[    3.928769] enp2s0: 0xffffc90000e78000, <MAC 'enp2s0' [IF1]>, IRQ 43
[    4.011951] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[    6.024208] r8168: enp2s0: link up
[    6.024512] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
########## wireless info END ############
TheM00s3
  • 111
I fixed the problem above by simply reverting to Ubuntu 14.04.
TheM00s3
  • 111
