11
I have Ubuntu 16.04 installed and running fine. It boots from an SSD and has a larger HD for storage.
I would like to install Windows 10 for gaming and have bought an SSD specifically for Windows.
Normally you would go the other way around, Windows first and then Ubuntu, but I don't really want to reinstall Ubuntu.
Is disconnecting the two "Linux" hard drives and only connecting the new SSD for Windows, while installing Windows the way to go? Afterwards I would connect all three HDs and set the Ubuntu SSD as the boot drive.
I don't mind having to go into the BIOS when I need to boot in Windows, if necessary.
TLDR: Ubuntu installed on SSD, want Windows 10 installed on second SSD. Disconnect Ubuntu SSD, install Windows 10, reconnect Ubuntu SSD, boot from desired SSD. Feasible?
Nis
  • 291
I went ahead and did it. The operation was successful.
I:
  1. Disconnected the Linux HDs
  2. Connected the new SSD
  3. Installed Windows on the new SSD
  4. Reconnected the Linux HDs
  5. Set the Linux SSD as default boot-drive
  6. Booted into Ubuntu
  7. Mounted the Windows partition in Nautilus
  8. Ran sudo update-grub
Grub now presents me with a list on startup were I can choose between Ubuntu and Windows.
The only small problem I had was in step 7. For some reason Ubuntu claimed that Windows had not shut down properly and thus could't mount the disk. A quick reboot into Windows and then back into Ubuntu solved it, and the drive mounted fine.
I'm not sure if disconnecting the Linux HDs were actually necessary. I did it to be extra sure I wouldn't accidentally mess up the Ubuntu installation. The Windows and Ubuntu installs are on identical SSDs.
Nis
  • 291
