i was trying this tutorial(https://help.ubuntu.com/community/EOLUpgrades#SpecificOlder) to upgrade Ubuntu 10.04, but always failed. source.list
deb http://old-releases.ubuntu.com/ubuntu/ lucid main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ lucid-updates main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ lucid-security main restricted universe multiverse
i execute the command : sudo do-release-upgrade -d the last display on terminal is :
Restoring original system state
Aborting
Reading package lists... Done
Building dependency tree
Building data structures... Done
During upgrading, there are some error when loading Failed Read Mirror File
and error
 Hit http://old-releases.ubuntu.com lucid-security/universe Packages
    Hit http://old-releases.ubuntu.com lucid-security/multiverse Packages
    Err http://archive.ubuntu.com lucid-updates/main Packages
      404  Not Found [IP: 2001:67c:1360:8001::21 80]
    Fetched 0B in 0s (0B/s)
i dont know where archive. ubuntu. com come from, there is no on my source.list
i also follow this solution (askubuntu. com/questions/91815/how-to-install-software-or-upgrade-from-an-old-unsupported-release), but not work on me, the error still occur
Any solution? thank you
rey1024
Can you test if your internet connection is IPv6 ready with http://www.test-ipv6.com? Maybe that's the problem. If you can't connect via IPv6, then try the following:
1. In Terminal, type "pkexec gedit /etc/gai.conf"
2. Uncomment (i.e. remove "#" at the beginning) the line "precedence ::ffff:0:0/96 100"
After that, IPv4 connection should be used and upgrade process should work.
Others have found that the update reports an authentication problem, and lists all the packages that were unauthenticated, then does a rollback.
According to this: https://bugs.launchpad.net/ubuntu/+source/update-manager/+bug/1513232
there's a bug where the 12.04 packages appear to be unauthenticated to the do-release-upgrade. The bug report includes a couple of potential workarounds. The one suggested in the original report worked for me.
