Application use java. When run script, it returns
./browser.sh ./browser.sh: 7: ./browser.sh: java: not found
I check java version:
java -v
The program 'java' can be found in the following packages:
 * default-jre
 * gcj-4.8-jre-headless
 * openjdk-7-jre-headless
 * gcj-4.6-jre-headless
 * openjdk-6-jre-headless
Try: sudo apt-get install <selected package>
Which package should I install?
minto
  • 831
You could install the default-jre, that is openjdk-7.
This should be the more stable of all jre.
Very easy :
sudo add-apt-repository ppa:webupd8team/java
After that, update package lists via:
sudo apt-get update
To install Oracle Java 8, run:
sudo apt-get install oracle-java8-installer
Change the number 8 to 6 (or 7) in the code to install Java 6 (or 7).
To set the default Java, run:
sudo apt-get install oracle-java8-set-default
Also change number 8 to the Java version you want.
Finally check whether everyting is OK:
java -version
Nullpointer
  • 1,191
  • 16
  • 34
The best way to install JDK on ubuntu is manually by downloading from oracle. You can refer following documentation for easy installation.
6 Easy way to install Java JDK on Ubuntu
