After a fresh install the nexus 4 didn't even see any networks. Following other advice I downgraded the radio to something prior to 4.4 using
fastboot flash radio ~/Downloads/radio-mako-m9615a-cefwmazm-2.0.1700.33.img
After I rebooted I could see the network in my building but when I try to connect and enter the password it just doesn't do anything. I originally thought it still had to do with the radio but I can connect to two other networks without problem. I believe all 3 (one no-connect, two connect) are WPA. Passwords formulas are as follows
Connect 1  - 10 numbers
Connect 2  - 6 Mixed case letters followed by 4 numbers
No Connect - 8 Mixed case letters, an underscore, 4 numbers
On the netork that won't connect, if I go in and change the wifi password (and don't touch anything else) it will connect fine. I simply went to the wireless page, change the password temporarily to 10 numbers, clicked save, opened up the wifi on my phone and connected. After that I went back to the original password (it is used by the whole company) and sure enough I can't connect.
Must this have something to do with the passwords, some kind of bug, or is there other information that I should provide or check?
UPDATE: Public wifi at a coffee shop works. As far as I can tell it is just that password (or something about it) on one network.
