That command below worked fine on Ubuntu 14.04. After upgrade to 16.04 it does not work anymore. It opens a terminal window with 4 tabs.
open-terminals.sh
#!/bin/bash
gnome-terminal --load-config=terminal-config.cfg &>/dev/null &
terminal-config.cfg
#Written by GNOME Terminal 3.6.2
[GNOME Terminal Configuration]
Version=1
CompatVersion=1
Windows=Window0;
[Window0]
MenubarVisible=true
Role=gnome-terminal-window-6355-887453268-1466588933
ActiveTerminal=Terminal0xed4f70
Geometry=135x24+437+495
Terminals=Terminal0xe04970;Terminal0xc1f520;Terminal0xe4f060
[Terminal0xe04970]
ProfileID=Default
Title=am.example.com
WorkingDirectory=/home/.../servers/apache-tomcat-am/bin
Zoom=1
Width=135
Height=24
[Terminal0xc1f520]
ProfileID=Default
Title=web.example.com
WorkingDirectory=/home/.../servers/apache-tomcat-web/bin
Zoom=1
Width=135
Height=24
[Terminal0xe4f060]
ProfileID=Default
Title=middleware.example.com
WorkingDirectory=/home/.../servers/payara-middleware/bin
Zoom=1
Width=135
Height=24
[Terminal0xed4f70]
ProfileID=Default
Title=api.example.com
WorkingDirectory=/home/.../servers/glassfish-api/bin
Zoom=1
Width=135
Height=24
At first I got a "Error creating terminal: "Default" is not a valid UUID" error. I fixed it so that I put a real uuid to ProfileIDs.
Next error what I got was "Error creating terminal: No profile with UUID "e4661004-d5fd-4d17-9a9d-8e419b6b8330" exists". I fixed it so that I changed the value of Terminals in [Window0] to the ProfileIDs.
Next problem: Title and WorkingDirectory properties are not applied and i just realized that the "rename tab" menu is disappeared from the menu.
GNOME Terminal
3.18.3
A terminal emulator for the GNOME desktop
Using VTE version 0.42.5 +GNUTLS
Could you please help me to fix this issue?
update
gnome-terminal --save-config=~/temp/xyz.cfg says that Option "--save-config" is no longer supported in this version of gnome-terminal.
What is that? What is is the alternative way to do the same with the new version of gnome-terminal? I have not found any useful about this topic on the internet :(
