I have a brother HL-L2340DW.
The "Printers" application shows it is installed.
However, "Print Test Page" is greyed-out.
Also, when I try printing a pdf nothing gets sent to the print queue.
Any ideas how to troubleshoot?
Try this:
Download the tool: http://download.brother.com/welcome/dlf006893/linux-brprinter-installer-2.0.0-1.gz
The tool will be downloaded into the default "Download" directory, e.g. /home/UserName/Download
Open a terminal window:
Press Ctrl+Alt+T
Go to the directory you downloaded the file to in the last step:
cd /home/UserName/Download
Enter this command to extract the downloaded file:
gunzip linux-brprinter-installer-2.0.0-1.gz
Get superuser authorization with the sudo command:
exec sudo -i
Run the tool:
bash linux-brprinter-installer-2.0.0-1 HL-L2340DW
The driver installation will start. Follow the installation screen directions.
When you see the message "Will you specify the DeviceURI ?",
For USB Users: Choose N(No)
For Network Users: Choose Y(Yes) and DeviceURI.
The install process may take some time. Please wait until it is complete.
This link helped me, here are the instructions it lays out in case the link doesn't work in the future:
STEP 1 tells you to download the tool, but to avoid giving links that might not stand valid in the future, just google: "linux brother printer driver tool installer" and it should be provided by the brother printer website.
"Step1. Download the tool.(linux-brprinter-installer-..-.gz)
The tool will be downloaded into the default "Download" directory. (The directory location varies depending on your Linux distribution.) e.g. /home/(LoginName)/Download
Step2. Open a terminal window.
Step3. Go to the directory you downloaded the file to in the last step. By using the cd command.
e.g. cd Downloads
Step4. Enter this command to extract the downloaded file:
Command: gunzip linux-brprinter-installer-..-.gz
e.g. gunzip linux-brprinter-installer-2.1.1-1.gz
Step5. Get superuser authorization with the "su" command or "sudo su" command.
Step6. Run the tool:
Command: bash linux-brprinter-installer-..- Brother machine name e.g. bash linux-brprinter-installer-2.1.1-1 MFC-J880DW
Step7. The driver installation will start. Follow the installation screen directions.
For USB Users: Choose N(No) For Network Users: Choose Y(Yes) and DeviceURI number.
The install process may take some time. Please wait until it is complete."
