I am using Ubuntu 14.04 64bit OS and I cannot install 32 bit libraries for Android studio. It shows my packages are broken. I don't know how to install following code. It shows dependency issue.
sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0
Building dependency tree
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
lib32bz2-1.0 : PreDepends: libc6-i386 (>= 2.9-18) but it is not going to be installed
lib32ncurses5 : Depends: lib32tinfo5 (= 5.9+20140118-1ubuntu1) but it is not going to be installed
Depends: libc6-i386 (>= 2.4) but it is not going to be installed
lib32stdc++6 : Depends: lib32gcc1 (>= 1:4.1.1) but it is not going to be installed
Depends: libc6-i386 (>= 2.17) but it is not going to be installed
lib32z1 : Depends: libc6-i386 (>= 2.4) but it is not going to be installed
Anyone can help me please.
Shashanth
  • 463
You can try adding the 32bit architecture in dpkg - sudo dpkg --add-architecture i386, or you could try editing your /etc/apt/sources.list file, adding the Ubuntu 12.04 repository, and running sudo apt-get update.
