I can't establish wired Internet connection on my desktop pc. It tries to connect to "wired connection 1" and even if, after minutes, it finally (not always) manages to "connect"(according to the network indicator icon on panel) , I have no Internet.. Does any solution exist?
:~$ ping google.com
ping: unknown host google.com
terminal:
:~$ ifconfig
enp0s4 Link encap:Ethernet HWaddr 00:1d:60:a1:87:5b
inet6 addr: 2a02:587:d06:c500:44ef:f096:fe1c:fcff/64 Scope:Global
inet6 addr: fe80::1542:7931:b71a:1a06/64 Scope:Link
inet6 addr: 2a02:587:d06:c500:1070:a40c:9369:f2a1/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:23 errors:0 dropped:0 overruns:0 frame:0
TX packets:428 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1984 (1.9 KB) TX bytes:45238 (45.2 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2008 errors:0 dropped:0 overruns:0 frame:0
TX packets:2008 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:213140 (213.1 KB) TX bytes:213140 (213.1 KB)
terminal:
:~$ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
terminal:
:~$ cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.1.1
terminal:
:~$ sudo lshw -C network
*-network
description: Ethernet interface
product: 191 Gigabit Ethernet Adapter
vendor: Silicon Integrated Systems [SiS]
physical id: 4
bus info: pci@0000:00:04.0
logical name: enp0s4
version: 02
serial: 00:1d:60:a1:87:5b
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=sis190 driverversion=1.4 duplex=half latency=0 link=yes multicast=yes port=MII speed=10Mbit/s
resources: irq:19 memory:fbffcc00-fbffcc7f ioport:ec00(size=128)
terminal:
:~$ cat /etc/NetworkManager/NetworkManager.conf
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
terminal:
:~$ cat /var/lib/NetworkManager/NetworkManager.state
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
terminal:
:~$ ip -6 route show
2a02:587:d06:c500::/64 dev enp0s4 proto kernel metric 256 expires 85777sec pref medium
fe80::/64 dev enp0s4 proto kernel metric 256 pref medium
default via fe80::1 dev enp0s4 proto static metric 100 pref medium
terminal:
:~$ ping6 -c4 2001:4860:4860::8888
PING 2001:4860:4860::8888(2001:4860:4860::8888) 56 data bytes
From 2a02:587:d06:c500:496e:2d4f:aff4:7285 icmp_seq=1 Destination unreachable: Address unreachable
From 2a02:587:d06:c500:496e:2d4f:aff4:7285 icmp_seq=2 Destination unreachable: Address unreachable
From 2a02:587:d06:c500:496e:2d4f:aff4:7285 icmp_seq=3 Destination unreachable: Address unreachable
From 2a02:587:d06:c500:496e:2d4f:aff4:7285 icmp_seq=4 Destination unreachable: Address unreachable
--- 2001:4860:4860::8888 ping statistics ---
4 packets transmitted, 0 received, +4 errors, 100% packet loss, time 3015ms
"kalimera" is a configuration file for wirelless connection. No configuration file for Ethernet connection here. terminal:
: /etc/NetworkManager/system-connections$ ls
kalimera
I tried to find a solution in older posts with no luck. I have this issue since lubuntu 15.10. Recently i have installed the new version of lubuntu 16.04 which i currently use, but so far No difference. The pc is dual boot and in the other OS everything works fine. So i assume it is not a hardware issue. I'm not exactly too familiar with linux. Thanks a lot!
