I have installed Lubuntu on my old laptop/netbook. I am having issues with the display drivers, it's stuck on one resolution 840x600. That is the only option available. The laptop ran fine at 1024x600 with Peppermint 7, and Ubuntu 10.somthing.
The card is VIA P4M900, VN896, CN896 Chrome9. Driver: fbdev (unloaded: Vesa)
I at one point uninstalled fbdev and was able to change resolution to several different options but ones I reboot the computer I had a black screen with blinking cursor, I got to a command line reinstall fbdev and back to same resolution issue.
I also tried this:
Sudo nano /etc/default/grub
from
uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
to
Uncomment to disable graphical terminal (grub-pc only)
and make it active by running
sudo update-grub
and reboot the computer.Then I had black screen with blinking cursor, so I put it back to how it was using a command line and back to same issue with display.
Anyone have any help or ideas?
FYI. The latest Ubuntu, mate, mint all won't work and I have a black screen with a blinking cursor.
Rybena
The solution suggested here worked for me: How to set up VIA chrome9 screen driver?
I've just installed Lubuntu on my old HP Mini (coincidence!) and had the same issue with the screen resolution. Running
 sudo apt-get install xserver-xorg-video-openchrome
and rebooting worked for me.
ronan
Likely due to the lack of KMS (Kernel Mode Setting) support, OpenChrome got dropped from default support of the device driver. You should first install xserver-xorg-video-openchrome package first.
After that, I recommend updating OpenChrome code by manually compiling the upstream code.
https://lists.freedesktop.org/archives/openchrome-users/2016-February/007237.html
Regards,
Kevin Brace
The OpenChrome Project maintainer / developer
