So I am running a fresh copy of Ubuntu Server 16.04 (Did install the Ubuntu-desk on top of it but otherwise stock)
I installed zfsutils-linux then using instructions from the Ubuntu zfs kernel reference site I was able to create a raidz pool. I made some file systems on it and started copying files to it.
Upon reboot the system doesn't recognize the pool at all. A "sudo zpool status" returns nothing.
If I do these two commands after it reboots(storage is the name of the pool):
sudo zpool import storage
sudo zfs mount -a
This will connect the pool and I am fine until next reboot.
When i do a normal reboot the root drive ends up being /dev/sdb
I have tried adding these two commands to the rc.local file but the drive names are out of order. I am assuming due to the fact my main drive is a slower older drive and probably takes time to spin up.
The pool drives are all consumer grade 2 TB drives and the boot disk is a consumer grade 500 gig drive. I use this computer as a test machine and as a backup to my other server. This server has currently 32 gig of ram and is a "9" series supermicro server motherboard with xeon processor so it has more than enough power to run as a home server.
I REALLY want this to work automatically and my other option is to put a delay before the commands but I have to believe it should automatically mount the drive somehow but I have not found how in the documentation or in any searches online.
Thanks for any help!
