I am trying to upgrade eclipse to the latest version, neon.
I have downloaded the tar.gz and untarred it. I open the directory and there is a file eclipse-inst.
If I don't run it as sudo it fails to install. If I do run it as sudo it tries to set everything into areas for /root and then I can't access them later.
For example, I "pinned" the apparent "launcher" button but clicking it now achieves nothing.
The only way I can seem to get back is as a super-user.
Trying to run it otherwise gives me:
The Eclipse executable launcher was unable to locate its companion shared library`
I can run it with
sudo eclipse
but I don't want to have to run it as a super-user.
When trying to install on my own account I get:
[2016-08-03 18:10:34] ERROR: org.eclipse.equinox.p2.metadata.repository code=1002 Unable to read repository at http://download.eclipse.org/technology/epp/packages/neon. java.io.IOException: Permission denied at java.io.UnixFileSystem.createFileExclusively(Native Method) at java.io.File.createNewFile(File.java:1012) at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:391) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCacheFromFile(CacheManager.java:132) at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.getLocalFile(XZedSimpleMetadataRepositoryFactory.java:56) at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.load(XZedSimpleMetadataRepositoryFactory.java:78) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:116) at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:370) at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:177) at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:437) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1625) at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:416)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
CashCow
  • 231
You must change user owner and permissions of the installer. If the problems persist, try the same on the installation folder and files:
sudo chown <yourUserName> <file>
sudo chown -R <yourUserName> <folder>
sudo chmod 0644 <file>
sudo chmod 0644 -R <folder>
Where <yourUserName> is your user name, and <file/folder> the file or folder to process.
Try to install Eclipse on a separated folder in your Home folder, for example: /home/$USER/Programs/Eclipse
GTRONICK
  • 4,344
