I recently installed Ubuntu 16.04 as my Default and only OS. Whenever I boot up, A Grub Menu Appears and I need to choose a option manually. Since every time my only option will be 'Ubuntu' Therefore I want that My Laptop should directly boot into Ubuntu without asking it.
Is there a way to speed up this process and disable Grub?
Apaar
You cannot disable GRUB. What you can do though, is alter the value of GRUB_TIMEOUT in the /etc/default/grub file so that the system doesn't wait for you to select something. In a terminal execute the following commands:
sudo nano /etc/default/grub
Find the line containing GRUB_TIMEOUT= and change the value to 0. Save the file and execute:
sudo update-grub
for the changes to take effect. You will never see the GRUB menu again.
I have to warn you though that doing this will result in you having to keep Shift pressed while booting, if you need to access the GRUB menu for any reason.
Stormlord
  • 6,807
