I absentmindedly shut down my machine during the upgrade. Now Linux gives me the login screen, and after that the home screen with no launcher icons some graphical glitches.
I believe booting from USB and trying to repair the install will fix the problem; is this correct? Or is there something I can do using the shell via Ctrl-Alt-F1 ?
Thanks in advance!
Try the following commands after you login :
sudo dpkg --configure -a
sudo apt-get install -f
and then
sudo apt-get update && sudo apt-get dist-upgrade
that should fix the broken packages if any
pratikad
  • 111
