I was trying to install a hard drive by following the InstallingANewHardDrive guide on help.ubuntu.com, but I accidentally formatted my 2 TB external hard drive instead of my 1 TB internal hard drive.
I'm running Ubuntu 14.04 and I have 3 hard drives:
  1. 80gb Intel SSDSC2BW080A4 (DC22) master boot record
  2. ST1000DM003-1ER162 (CC43) GUID Partition Table (the one i wanted to install and mount)
  3. My 2 TB Segate external Hard Drive that now is inaccessible and formatted.
When i go to my disks tool and choose this hard drive it tells me that its 1.6% full, which sounds like good news to me.
I read a couple of different post look into some programs but I'm not really sure how to proceed.
results of the deep analysis with testdisk
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63
The harddisk (2000 GB / 1863 GiB) seems too small! (< 17833196 TB / 16219197 TiB Check the harddisk size: HD jumpers settings, BIOS detection...
The following partitions can't be recovered:
Partition Start End Size in sectors
VMFS 38417 201 39 3789016855 14 45 3924794316768135
SysV 4 49694 147 2 7723719 218 31 123283216128 [^\%^DK]
VMFS 138906 191 51 3432453218 29 16 34830459532972999
XFS 4 179830 196 24 1053386502 20 50 17956568663837018 [~[JR4
NTFS 243201 0 63 486402 0 62 3907024065
i probably should have mentioned that im very new to this. so cant really make sense of any of that.
Well, you could get some of the files back by scanning the drive with forensic tools. But other then this I think it's not possible that easy. The mkfs tools overwrite specific sections for file system information. without a backup of these blocks I believe its not possible to restore the structure of the old file system. What I like to do is not to install OS on hard-drive. Use a usb-thumb flash-drive. It's easy to do an image-backup then and in such situations you can simply do a dd back to the usb-thumb :) Sorry to not provide you a better solution.
0x0C4
  • 713
You can use forensic tools and try recover at least some of the data. My experience with those was very mixed as the results you will be getting will be a big pile of data, some of which will even be broken. Nonetheless they can really recover your important data. (And recover the data to a new disk and not the one you are about to examine)
More information on file recovery including many tools can be found in the Arch Linux Wiki
matt3o
  • 971
