I'm getting the following errors when installing Skype.
 skype : Depends: skype-bin
 unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
                        Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I don't know how to remove the broken packages.
karel
  • 122,292
  • 133
  • 301
  • 332
Since the output of uname -a gives x86_64, it means that you have a 64 bit version.
I suggest that you first try to remove traces of your skype install. You can do this by entering sudo apt-get purge skype in your terminal. It might be possible that you have to run sudo apt-get purge skype-bin also.
Then check if you have any held packets: Open the /var/log/dist-upgrade/apt.log log file in a text editor. Locate any "broken" packages and remove them with sudo apt-get remove .
Note: in newer versions, the log is located in /var/log/apt/term.log instead.
To install Skype again, you should first run following command
sudo dpkg --add-architecture i386
Add the correct repository:
sudo add-apt-repository "deb http://archive.canonical.com/ $(lsb_release -sc) partner"
Then update & install Skype:
sudo apt-get update && sudo apt-get install skype
Noosrep
  • 2,184
