I have been reading about the locate command, and the tutorial I was using says that /var/log/updatedb is where the updatedb is located. It is not there on ubuntu (xubuntu), and it doesn't even seem to be locate-able (ironically) in principle. This is what I have done to try and find it:
[HOST]:~$ sudo find / -name updatedb
[sudo] password for [USERNAME]:
find: ‘/run/user/1000/gvfs’: Permission denied
/etc/alternatives/updatedb
/usr/bin/updatedb
if I look in /usr/bin and long-list updatedb, it is linked (light blue link - and with an 'l' in the permissions, so a symlink) to /etc/alternatives/updatedb.
if I look in /etc/alternatives
[HOST]:/usr/bin$ cd /etc/alternatives
[HOST]:/etc/alternatives$ ls -l updatedb
lrwxrwxrwx 1 root root 25 Jul 15 02:35 updatedb -> /usr/bin/updatedb.mlocate
you get the above symlink to /usr/bin/updatedb.mlocate
[HOST]:/usr/bin$ ls -l updatedb.mlocate
-rwxr-xr-x 1 root root 43768 Nov 18 2014 updatedb.mlocate
[HOST]:/usr/bin$ file updatedb.mlocate
updatedb.mlocate: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=85d4fb92c2e099510893b0c2eccb13d49943e81e, stripped
I then read this link on ubuntu:
Ubuntu Manpage: updatedb - update a database for mlocate
Which says that the database is in /var/lib/mlocate.db, but this (just below) is what I got, and when opened in a text editor the message was that the data was unreadable:
[HOST]:/var/lib/mlocate$ ls
mlocate.db
[HOST]:/var/lib/mlocate$ emacs mlocate.db
[HOST]:/var/lib/mlocate$ file mlocate.db
mlocate.db: regular file, no read permission
[HOST]:/var/lib/mlocate$ ls -l mlocate.db
-rw-r----- 1 root mlocate 5291101 Aug 1 08:45 mlocate.db
I expect I just have a conceptual misunderstanding, but would be grateful for any comments that would help me understand where the database can be found.
