12
I know that Ubuntu 10.04 is no longer supported.
But I am still using it, becuase I use virtual machine (VirtualBox), and on previous trials to use any more updated Ubuntu version was too heavy, and slow, in my machine.
Now, when I try doing:
apt-get update
I receive a bunch of errors:
Ign http://il.archive.ubuntu.com lucid-updates/multiverse Packages
Ign http://il.archive.ubuntu.com lucid-updates/multiverse Sources
Err http://il.archive.ubuntu.com lucid/main Packages
  404  Not Found
Err http://il.archive.ubuntu.com lucid/restricted Packages
  404  Not Found
Err http://security.ubuntu.com lucid-security/main Packages
  404  Not Found [IP: 91.189.88.162 80]
W: Failed to fetch     http://il.archive.ubuntu.com/ubuntu/dists/lucid/universe/binary-i386/Packages.gz  404  Not Found
I am sure I used to do that in the past without any issues.
Is it because Ubuntu 10.04 was removed from these repositories, or is it some other issue?
techraf
  • 3,316
ransh
  • 313
To complement techraf's answer, if you want to use old releases, you can access them using this address:
http://old-releases.ubuntu.com
To enable this, open the /etc/apt/sources.list file with a text editor, and wherever you see archive.ubuntu.com (the source of releases actively supported), change it to old-releases.ubuntu.com (you can use the find & replace option to speed it up).
It's really trivial to verify, just browse to http://il.archive.ubuntu.com/ubuntu/dists/ (you can also drop theil from the front) and check the results.
The site is responding, you get a connection, but there is no lucid among the directories corresponding to Ubuntu releases.
Conclusion: the packages were removed.
techraf
  • 3,316
