I have just installed ubuntu 16.04 LTS. When I choose try before installing, wifi was not working. So I activated wifi driver by Software & Updates >> Additional Drivers and It was working while installing (and try before installing).
But after installing, I am not able to activate by same procedure. When I enable and input my password, it does nothing.
Output of lspci --vvnn | grep -A 9 Network
07:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
Subsystem: Dell Wireless 1704 802.11n + BT 4.0 [1028:0016]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 19
Region 0: Memory at f7c00000 (64-bit, non-prefetchable) [size=32K]
Capabilities: <access denied>
Kernel driver in use: bcma-pci-bridge
Kernel modules: bcma
output of iwconfig
lo no wireless extensions.
enp9s0 no wireless extensions.
My problem is I just installed Ubuntu 16.04 and not able to enable wireless driver.
-- Software & Updates >> Additional Drivers
-- Select Using Broadcom 802.11 Linux STA Wireless driver source from ....
-- When I insert password, nothing happen, It still selected Do not use this device
