There are tons of questions related to disabling default behavior of Alt+<some key> in Ubuntu. My problem, however, is a little different. Whenever the Alt key is pressed, it triggers the menu bar selection (with the action letter underlined). While this is great in general, in Inkscape it leads to a lot of problems.
Please note that my question is not related to HUD or Unity bar. It's a global behavior no matter which application I'm running. How can I disable the action related to pressing Alt key only in Inkscape only (best case) or if that isn't possible, everywhere?
ankush981
  • 321
Run command ccsm in terminal (If you don't have that installed, it will show). Go to Desktop → Ubuntu Unity Plugin and change the "Key to show the menu bar while pressed".
Source: How to stop Alt from triggering Global Menu?
Igorzovisk
  • 208
