I have a system with three drives, one ntfs boot ssd for windows 10, one ntfs hdd for storage, and another to install ubuntu on.
I am getting the
Force UEFI Installation? This machines's firmware has started this installer in UEFI mode but it looks like there maybe existing operating systems already installed using BIOS compatibility mode, If you continue to install Debian in UEFI mode,it might be difficult to reboot into any BIOS-mode operating system.
Message, so I tried both booting from the live usb in non uefi (doesn't boot at all, just goes straight to windows), and installing by forcing uefi - this installs successfully, but will not boot, even with the other drives disconnected.
The motherboard in use is an Asus P8Z77-V, and as many 'fast-boot' settings as I can find are turned off.
parted -l:
Model: ATA WDC WD10EZEX-00W (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 525MB 524MB primary ntfs boot
2 525MB 1000GB 1000GB primary ntfs
Model: ATA KINGSTON SUV400S (scsi)
Disk /dev/sdb: 120GB
Disk Flags:
1 1049kB 120GB 120GB primary ntfs
Model: ATA WDC WD3200AAKS-0 (scsi)
Disk /dev/sdc: 320GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 EFI System Partition boot, esp
2 538MB 312GB 311GB ext4
3 312GB 320GB 8455MB linux-swap(v1)
