Problem: I followed the intructions for installing Ubuntu 16.04 over an EFI system with LUKS+LVM of this upvoted question on AskUbuntu, but I ended up with a somewhat unusable system.
The only thing that I changed was the size/order of the partitions, and the device on which I performed the partitioning.
This is the output of lsblk, the disk of interest is /dev/sdb/:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931.5G 0 disk
└─sda1 8:1 0 931.5G 0 part
sdb 8:16 0 596.2G 0 disk
├─sdb1 8:17 0 976M 0 part
├─sdb2 8:18 0 977M 0 part /mnt/root/boot
└─sdb3 8:19 0 594.3G 0 part
└─crypt 252:0 0 594.3G 0 crypt
├─vgcrypt-lvcryptswap 252:1 0 16G 0 lvm
├─vgcrypt-lvcryptroot 252:2 0 50G 0 lvm /mnt/root
└─vgcrypt-lvcrypthome 252:3 0 528.3G 0 lvm
sdc 8:32 0 119.2G 0 disk
├─sdc1 8:33 0 260M 0 part
├─sdc2 8:34 0 16M 0 part
├─sdc3 8:35 0 118.5G 0 part
└─sdc4 8:36 0 499M 0 part
sdd 8:48 1 7.6G 0 disk
└─sdd1 8:49 1 7.6G 0 part /cdrom
loop0 7:0 0 1.4G 1 loop /rofs
mmcblk0 179:0 0 1.9G 0 disk
└─mmcblk0p1 179:1 0 1.9G 0 part /media/ubuntu/31FCE9E42220D4BE
The lvm in the luks partition /dev/sdb3 is called crypt and contains swap, root and home.
The remaining disks are used by windows 10, so I left them untouched.
After getting the uuid of /dev/sdb3 from blkid:
/dev/sda1: LABEL="DATA" UUID="2AE43A49E43A1791" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="2a7b3856-3192-47aa-8554-b6cfb2f04a8f"
/dev/sdb1: UUID="2943-F2AC" TYPE="vfat" PARTUUID="ae1b8a40-ac1a-43c7-9ea5-6a5af9ab3a8e"
/dev/sdb2: UUID="3db754a7-09c6-482f-935d-01a6eb0b73f6" TYPE="ext4" PARTUUID="6f366b6f-8a81-4b48-9c4a-430587cc036c"
/dev/sdc1: LABEL="SYSTEM" UUID="C046-94A0" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="5476cd55-9ffe-4117-8ae9-0327ef674d98"
/dev/sdc3: LABEL="OS" UUID="5C3A4A083A49E01E" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="f4cfabec-46df-4b83-8fb3-3046fa637d17"
/dev/sdc4: LABEL="RECOVERY" UUID="4EAE64A2AE6483F5" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="96888350-a7f1-44f7-9088-84e7978f5fe0"
/dev/sdd1: UUID="B700-D919" TYPE="vfat" PARTUUID="14f70980-bceb-4945-a267-d9877f147b2a"
/dev/loop0: TYPE="squashfs"
/dev/sdb3: UUID="132a57e3-b7dd-4404-9782-944a050d3153" TYPE="crypto_LUKS" PARTUUID="0a24c795-1346-4c5d-9018-620f4bf28785"
/dev/mmcblk0p1: UUID="31FCE9E42220D4BE" TYPE="ntfs" PARTUUID="0009e3b9-01"
/dev/mapper/crypt: UUID="6wnHdE-Vr7r-lECO-PcTi-aMz9-dnQY-5wY8ne" TYPE="LVM2_member"
/dev/mapper/vgcrypt-lvcryptswap: UUID="12f1b51a-1de2-4be1-ac8b-5c7ee92cf7d6" TYPE="swap"
/dev/mapper/vgcrypt-lvcryptroot: UUID="d45bfda9-7759-4eb2-a739-d4b55c6e3ecc" TYPE="ext4"
/dev/mapper/vgcrypt-lvcrypthome: UUID="1034f3c4-aafe-4086-b4ee-61af1f96ddea" TYPE="ext4"
/dev/sdc2: PARTLABEL="Microsoft reserved partition" PARTUUID="e5ed0f27-374d-4fb0-bf52-b7d6371cea51"
/dev/mmcblk0: PTUUID="0009e3b9" PTTYPE="dos"
I updated the /etc/crypttab file within the new system as adviced by the instructions:
crypt UUID="132a57e3-b7dd-4404-9782-944a050d3153" none luks
Since I wish to be prompted for the password each time, I did not configure a password file.
Currently, my /etc/fstab/ looks as follows
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/mapper/vgcrypt-lvcryptroot / ext4 errors=remount-ro 0 1
# /boot was on /dev/sdb2 during installation
UUID=3db754a7-09c6-482f-935d-01a6eb0b73f6 /boot ext4 defaults 0 2
# /boot/efi was on /dev/sdb1 during installation
UUID=2943-F2AC /boot/efi vfat umask=0077 0 1
/dev/mapper/vgcrypt-lvcrypthome /home ext4 defaults 0 2
/dev/mapper/vgcrypt-lvcryptswap none swap sw 0 0
AFAIK, this file was automatically generated during the installation process and it looks fine.
Error:
During the boot process, I am dropped to busybox with the following error message:
Volume group not found
Cannot process volume group vgcrypt
I am somewhat puzzled by this error, so far googling doesn't seem to return any useful answer among the first page results.
Question: would anyone know what is wrong in my setup and how I could fix it?
I already tried using
# update-initramfs -u -k all
And verified that lvm2 is installed in the new system, which is Ubuntu 16.04 with kernel 4.4.0-31-generic.
In case anyone thinks that it could be useful, here is the grub.cfg file:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt2 --hint-efi=hd1,gpt2 --hint-baremetal=ahci1,gpt2 3db754a7-09c6-482f-935d-01a6eb0b73f6
else
search --no-floppy --fs-uuid --set=root 3db754a7-09c6-482f-935d-01a6eb0b73f6
fi
font="/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=it_IT
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=10
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=10
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 44,0,30,0; then
clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-d45bfda9-7759-4eb2-a739-d4b55c6e3ecc' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
else
fi
linux /vmlinuz-4.4.0-31-generic.efi.signed root=/dev/mapper/vgcrypt-lvcryptroot ro quiet splash $vt_handoff
initrd /initrd.img-4.4.0-31-generic
submenu 'Opzioni avanzate per Ubuntu' $menuentry_id_option 'gnulinux-advanced-d45bfda9-7759-4eb2-a739-d4b55c6e3ecc' {
menuentry 'Ubuntu, con Linux 4.4.0-31-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-31-generic-advanced-d45bfda9-7759-4eb2-a739-d4b55c6e3ecc' {
recordfail
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
else
fi
echo 'Caricamento Linux 4.4.0-31-generic...'
linux /vmlinuz-4.4.0-31-generic.efi.signed root=/dev/mapper/vgcrypt-lvcryptroot ro quiet splash $vt_handoff nouveau.modeset=0
echo 'Caricamento ramdisk iniziale...'
menuentry 'Ubuntu, with Linux 4.4.0-31-generic (upstart)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-31-generic-init-upstart-d45bfda9-7759-4eb2-a739-d4b55c6e3ecc' {
recordfail
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
else
fi
linux /vmlinuz-4.4.0-31-generic.efi.signed root=/dev/mapper/vgcrypt-lvcryptroot ro quiet splash $vt_handoff init=/sbin/upstart
menuentry 'Ubuntu, with Linux 4.4.0-31-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-31-generic-recovery-d45bfda9-7759-4eb2-a739-d4b55c6e3ecc' {
recordfail
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
else
fi
linux /vmlinuz-4.4.0-31-generic.efi.signed root=/dev/mapper/vgcrypt-lvcryptroot ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows Boot Manager (su /dev/sdc1)' --class windows --class os $menuentry_id_option 'osprober-efi-C046-94A0' {
insmod part_gpt
insmod fat
set root='hd2,gpt1'
search --no-floppy --fs-uuid --set=root --hint-bios=hd2,gpt1 --hint-efi=hd2,gpt1 --hint-baremetal=ahci2,gpt1 C046-94A0
else
search --no-floppy --fs-uuid --set=root C046-94A0
fi
chainloader /efi/Microsoft/Boot/bootmgfw.efi
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'System setup' $menuentry_id_option 'uefi-firmware' {
fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
