I want my 16.04 to be able to hibernate to disk, it does not give that option now. I have a HP Pavillion x360 with 4 GB RAM. What should I do? Do you think it will help to shrink the Windows partition (sda3) by one GB and make swap size all together 5 GB? Or should I do something else? (Maybe 3.91 GiB is enough already?)
If I expand swap, will I then have to make any adjustments in the system. Or will Ubuntu automatically realize the swap has been enlarged?
Since I will be shrinking Windows 10 I thought I might use Windows 10 partitioning tools, also for enlarging swap. I don't have a bootable GParted USB at hand. Does that make a difference? (The system is dual boot.)
(I am in a period when I use Linux quite much for a project and I would appreciate hibernate to be present and also that I can install it smoothly, therefore I ask this before just trying around.)
Thanks
ycc@x360:~$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda5 during installation
UUID=c9b9e601-f78a-41d8-a4f4-87e276b4aeb7 / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda1 during installation
UUID=9ADF-D1D2 /boot/efi vfat umask=0077 0 1
# /home was on /dev/sda6 during installation
UUID=782e4b9f-4941-48bc-a1bf-5883e28cb174 /home ext4 defaults 0 2
# swap was on /dev/sda4 during installation
UUID=c35d5bd1-960c-4e1a-8f6e-d73af393bfc3 none swap sw 0 0
$ sudo parted -l
Model: ATA WDC WD5000LPCX-6 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 274MB 273MB fat32 EFI system partition boot, esp
2 274MB 290MB 16.8MB Microsoft reserved partition msftres
3 290MB 315GB 315GB ntfs Basic data partition msftdata
4 315GB 319GB 4194MB linux-swap(v1) Basic data partition msftdata
5 319GB 382GB 62.9GB ext4 Basic data partition msftdata
6 382GB 483GB 101GB ext4 Basic data partition msftdata
7 483GB 484GB 1028MB ntfs Basic data partition hidden, diag
8 484GB 500GB 16.1GB ntfs Basic data partition hidden, msftdata
