My problem:
I am connected to Ethernet "wired connection 1", I can see that in the network manager (the up and down arrows).
But when I open up Firefox or anything else that requires Internet connection, I get told the same thing: no Internet connection.
Information so far:
ifconfig:
$ ifconfig
enp3s0 Link encap:Ethernet HWaddr 94:de:80:c7:fd:2b
inet6 addr: fe80::f527:1269:a6f5:57e5/64 Scope:Link
inet6 addr: 2001:878:3ac:163:8a7:7349:6e60:d84/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:3 errors:0 dropped:47 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:848 (848.0 B) TX bytes:288 (288.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2292 errors:0 dropped:0 overruns:0 frame:0
TX packets:2292 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:171576 (171.5 KB) TX bytes:171576 (171.5 KB)
When I do ping google.com I get:
$ ping google.com
ping: unknown host google.com
When I look at /etc/network/interfaces I get:
$ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
auto eth
iface eth0 inet dhcp
I should note that no other devices have trouble connecting to the router, nor does Windows 7 when I dual boot to that.
I'm using Ubuntu version 16.04.
If you need more information, please do tell me.
edit 1
i pinged a website on the working computer and got an address, but nothing on the nonworking computer's firefox.
when i tried
$ /etc/resolv.conf
i got
command not recognized
I found a workaround in another post that might have the right information though.
kasper@kasper-To-be-filled-by-O-E-M:~$ cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
Edit 2
When I do
sudo lshw -C network
I get:
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 06
serial: 94:de:80:c7:fd:2b
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd
autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4
03/27/12 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:32 ioport:d000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
and when i do
sudo apt install r8168-dkms
as suggested in another post i get:
Reading package lists... Done Building dependency tree Reading
state information... Done E: Unable to locate package r8168-dkms
still no better after reboot.
