I need libxmu-dev and libxi-dev to be able to run OpengGl with CMake, but I can't seem to be able to install them.
When I run sudo apt install libxmu-dev libxi-dev the following happens:
Reading package lists... Done
Building dependency tree
 libxi-dev : Depends: libxi6 (= 2:1.7.5-1) but 2:1.7.6-1 is to be installed
 libxmu-dev : Depends: libxmu6 (= 2:1.1.2-1ubuntu1) but 2:1.1.2-2 is to be installed
How do I solve this?
You can install them using aptitude. It will suggest you different solutions to resolve the dependencies. Accept the one that downgrades the packages on which libxi-dev and libxmu-dev depend.
First, install aptitude:
sudo apt install aptitude
Then, install your packages using aptitude:
sudo aptitude install libxi-dev libxmu-dev
The first solution will be:
     Keep the following packages at their current version:
1)     libxi-dev [Not Installed]
2)     libxmu-dev [Not Installed]
Accept this solution? [Y/n/q/?]
Do not accept this solution. This will simply not install your packages. Enter n.
The next solution will be:
     Downgrade the following packages:
1)     libxi6 [2:1.7.6-1 (now) -> 2:1.7.5-1 (xenial)]
2)     libxmu6 [2:1.1.2-2 (now) -> 2:1.1.2-1ubuntu1 (xenial)]
Enter y to accept this solution. This will downgrade libxi6 and libxmu6, and then install libxi-dev and libxmu-dev.
Soroush
  • 126
