34
I tried disabling the motd.dynamic in /var/run renaming the file, but did not work because the system recreates the file.
Does anyone know disable it?
Sybil
  • 2,139
hdegenaro
  • 441
7 Answers7
55
Most answers need root access.
Any user can get a clean login(include disabling the MOTD), simply run:
touch $HOME/.hushlogin
Qinsi
  • 717
24
The script files in /etc/update-motd.d generate the file /var/run/motd.dynamic which you've identified as containing your MOTD.
A simplistic way to stop generating this file would be to make all of the scripts non-executable with:
chmod -x /etc/update-motd.d/*
Note: Information taken from this answer by heemayl.
Arronical
  • 20,241
20
Another way is to comment out these lines in /etc/pam.d/login:
#session    optional    pam_motd.so motd=/run/motd.dynamic
#session    optional    pam_motd.so noupdate
18
If anyone landed here because they specifically wanted to disable the "news" (ie. ads/promotional blurbs for things like macOS Kubernetes tooling) portion of the dynamic MOTD, but don't mind the rest being there (eg. the pending updates notification), that's easy too.
At the time I wrote this, this was the ad being displayed:
 * "If you've been waiting for the perfect Kubernetes dev solution for
   macOS, the wait is over. Learn how to install Microk8s on macOS."
https://www.techrepublic.com/article/how-to-install-microk8s-on-macos/
Just open up /etc/default/motd-news and set ENABLED=0.
ssokolow
  • 2,423
As per Alcuin Arundel's answer, also edit /etc/pam.d/sshd and comment out the pam_motd lines to remove the messages when entering through ssh.
pupitetris
  • 171
I found a workaround/hack
 ssh -t IP_ADDRESS bash
-t to force tty allocation
send the bash command, as sending a command doesn't output any of the bannery business.
have fun
There is configuration option in sshd_config, called PrintMotd. Setting it to no does the job.
Jakuje
  • 6,793
