yesterday I updated the kernel version to 4.2.0-42-generic through update manager. This unlucky event caused nvidia drivers to stop working, resulting in the famous login loop issue, after rebooting.
Today I found the same problem, for the very same reason, was reported in this launchpad bug few days ago.
Trying to fix that I messed things up a little bit, so I backed up my data and reinstalled ubuntu 14 without internet connection, which has kernel 4.2.0-27-generic. is there a way to manually upgrade to kernel 4.2.0-41-generic? maybe through apt?
Thanks
There was no need to re-install. You could simply boot with a previous kernel using grub menu.
Now kernel 4.2.0-41 is not available in the repositories.
If you are using Ubuntu 14.04, you can install kernel 4.4 by running
sudo apt-get install linux-generic-lts-xenial
Also the problem with Nvidia could appear because you did not disable Secure Boot in BIOS. With new kernels it is required to use propritary drivers.
Pilot6
  • 92,041
